| Home > Help Needed / General Tech Chat > Wiring LED\'s to toggle switch? | |||||||
64 Posts Member #: 8011 Advanced Member |
18th Apr, 2011 at 07:04:41pm
Hello all,
18th Apr, 2011 at 07:06:25pm
Fairly easy the output from the switch going to the rear screen put to the + leg of the led and earth the other leg Crystal Sound Audio said:
18th Apr, 2011 at 07:06:32pm
put the LED on the switched side with a 1k resistor inseries to ground. On 28th Aug, 2011 Kean said:
18th Apr, 2011 at 07:07:32pm
or follow Joes instructions Crystal Sound Audio said:
108 Posts Member #: 9182 Advanced Member |
18th Apr, 2011 at 09:11:25pm
Different LEDs will work best with different resistors.If you know the operating max current (7-50mA depending on colour)of the LED you can calculate the resistor.
18th Apr, 2011 at 10:35:21pm
I did as Joe says above. Works a treat...
In the 13's at last!.. Just |
![]() 392 Posts Member #: 5702 Senior Member Cornwall |
19th Apr, 2011 at 11:49:40pm
Did you have any issues with the hazard not being red?
