Home > General Chat > engine steady
bennyy
Member #: 9037
Doncaster, yorkshire
Hi lads
I've done a search but not found what I'm after, I'm not keen on the bracket on my standard engine steady, the one that is held down with one of the head bolts, I know there is a tapped hole in the block for a bolt, but does not line up with the eye of the original steady,, should I get an adjustable engine steady or is there an alternative/better way to do it? How have you got yours?
Cheers.
On 15th Mar, 2012 wil_h said:
On 30th Apr, 2012 Brett said:
benny i would help things along by getting a minispares btm engine steady kit the one under the flywheel housing job done up to 150 bhp ish ..........
phone ask for richard at minispares north
bennyy
Member #: 9037
Top engine steady all sorted now, I've got a lower engine steady one that bolts from the g'box to the front of the subframe, but I have no sleeve, nut or bolt for one end? Could do with it soon I'm at bogg brothers saturday morning then york for the weekend
pm me what it makes benny
bennyy
Member #: 9037
Will do steve engine feels a lot stronger with your head already and not even running it past 4k, are you going to york?
