Home > Help Needed / General Tech Chat > Modifying starter motor
haimesyboi
Member #: 5702
Cornwall
Has anyone moved their solenoid right out of the way so its right against the block or even remote?
I'm struggling with space behind my rad and I may be able to squeeze a second fan in if the solenoid disappears.
You can rotate it quite a bit by re drilling the hole closest the block and making a small bracket at the front.
I've got a pic somewhere of mine which i borrowed the idea from Matty.
Here you go...
haimesyboi
Member #: 5702
Cornwall
Thanks, its still going to be in the way with the motor rotated.
Im going to get a spare and give it a go, ideally trying to get the solenoid underneath the motor
Hi mate, I modified a hi torque starter but I am not using it any more that I will let go if you are looking.
simon.
MikeRace is after a hi-torque starter if its the inertia type.
Simon you have a pm.
Mike
