| Home > Help Needed / General Tech Chat > Whacking me T2 on a metty turbo lump | |||||||
28 Posts Member #: 9362 Member |
20th Apr, 2011 at 05:22:00pm
Ok, so i've just acquired a complete and original metro turbo engine, with only 16K on it!
20th Apr, 2011 at 05:28:56pm
firstley theres lots of questions there. all been answerd and discussed before!
20th Apr, 2011 at 05:33:58pm
I do apologise, i should of thought about having a quick gander round before, the main query i had was about the C/R so thanks for answering that
20th Apr, 2011 at 05:39:59pm
I which case, just make sure it's in good condition, get another actuator (5psi), intercooler and forget about the long list of stuff you listed.
In the 13's at last!.. Just |
20th Apr, 2011 at 05:43:31pm
Agree with the above. X pin diff a good idea as even a std engine can break the std diff. But otherwise as said lowish boost plus an intercooler should be good for 120bhp or so which will trounce the majority of 1380's etc in other road Minis.
20th Apr, 2011 at 06:33:33pm
On 20th Apr, 2011 theoneeyedlizard said:
I which case, just make sure it's in good condition, get another actuator (5psi), intercooler and forget about the long list of stuff you listed. This will net you a nice drivable motor and you can upgrade later once you get the taste for more boost (this will happen). I'll split the head off, check the bores and whack some new gaskets on Will also split the gearbox off and put a central pickup in and a 4 pin diff This way i guess it leaves me the scope for more power in the future, and it's not a big task to pull the engine and upgrade some bits an pieces So the standard clutch setup will be ok with around 5psi boost? I'll check the clutch plate when i split the box, and maybe put a new one in Definately will be running an I/C so all good there Sounds like a plan then, saves me sending off the head for work, i might put a duplex setup on just for piece of mind. Well with the cost saving of this option, i can sort out and order the megajolt and all the bits and pieces Edited by Monstrous on 20th Apr, 2011. |
20th Apr, 2011 at 07:33:56pm
AP turbo clutch will be fine.
20th Apr, 2011 at 07:40:09pm
Excellent
20th Apr, 2011 at 09:10:03pm
If it's a stock Metro Turbo lump 26cc in the head will give you 8.5-1 If you're only planning on running the stock 7psi Max boost then there's no need to lower the compression from standard. The stock clutch will be ok with a new AP plate fitted. |
