Home > Help Needed / General Tech Chat > Can i do a clutch change with the engine in place, no inner wings and removable front?
Clutch was playing up on me earlier, intermittanly slipping, pedal goes quite far down before it does anything. Im gonna try and bleed the system first and have a look for leaks, failing that im going into changing the clutch and slave cylinder.
And secondly, although a daft question and highly likely to be thrown in the bin, what are the little sticky back black pads for in the box of mintex m1144 pads ive just bought for 7.5" discs?
( reading the box it says also "Warning: This material must not be used on public highways." Yeah right....)
Edited by Carlzilla on 21st Apr, 2011.
easily with no inner wings and removable front
I can do mine in about 2 hrs and its all steel
yeah clutch is pretty easy with a removable front,
the sticky pads are probably anty squeal thingys.
Cheers lads :)
Off to minispares again tomorrow to get a clutch after some inspection. Trust the clutch to have played up on the way back from minispares, not on the way there :/
pot_dan
Member #: 326
bradford, west yorks
I also did mine in place. With fixed front and inner wings. Hardest thing I remember was the wok bolts!
As above, ive done it with a full front. To make ease on the refitment of the wok i slotted the bottom holes with a hack saw
madcatminis
Member #: 5327
Dudley, West mids
If you get stuck send me ya number and I'll pop over to help ya out. Im only up the road from you.
turbominij
Member #: 2104
Essex - UK
You should be able to do it very quick with no inner wings. It don't take that long with it all in there. As has been said the hard bit in the back 2 wock bolts but shortening them a little once out stops it being a problem again
"Tuning should be a compromise between what is possible and what is necessary"
10)Thou shalt always quest for more power
wintersurferuk
Member #: 2208
dont be a smart arse like me and put allen key bolt in the bottom.
Lol! I didnt want to say!
