Home > Help Needed / General Tech Chat > Rear brakes. Flexi hoses and banjos.
pot_dan
Member #: 326
bradford, west yorks
I have come to build my rear subframe up and noticed that the rear flexis I have had in the packet for about 4 years don't have the bolt for the banjo into the backplate/slave cylinder. So does anyone know where I can find one and what I am looking for?
pot_dan
Member #: 326
Sorry forgot to mention it's the goodridge braided ones I am replacing the old rubber ones.
A hydraulics place _may_ be able to help, otherwise you can order from somewhere like Merlin Motorsport or Demon Thieves.
You want a 3/8UNF banjo bolt to suit a -3 banjo fitting. Don't forget you'll need 4 off copper washers to do both sides.
pot_dan
Member #: 326
Thanks Tom. Very helpful. Will look at merlin first.
pot_dan
Member #: 326
I have found them on eBay but choice of long or short. To me this sounds vague but do you know witch it is supposed to be?
Short should be OK. Long are for when there are two hose fittings going onto 1 bolt. If in doubt ask the seller the length of the short bolt and measure your banjo fitting.
I made this mistake, you NEED the long ones.
