| Home > General Chat > Plugging Block | |||||||
![]() 399 Posts Member #: 793 Senior Member Milton Keynes |
22nd Apr, 2011 at 09:08:44pm
Now I'm attempting to dry deck the block (waterways only). I would like to use malleable iron ie bspt pipe threads as it's a compatable material. I didn't want any plugs below the surface, as I wanted to skim them flush. The small hole would have to be 1/8 bspt, but the 3 large holes arn't quite small enough to tap out 1/4 bspt and still allowing the plug to be machined flush ! The next size up is 3/8 and I was wondering if anyone new of any alternatives, as I didn't want to go as big as 3/8. http://i28.photobucket.com/albums/c248/spe...er1/mini007.jpg
24th Apr, 2011 at 06:45:14am
i have used 3/8 with no problems, i think this is your only option |
24th Apr, 2011 at 07:58:36am
M14 is about half way between.
24th Apr, 2011 at 11:00:16am
I did mine M8 and 9/16unf, another option for you. On 28th Aug, 2011 Kean said:
24th Apr, 2011 at 11:35:52am
http://cgi.ebay.co.uk/CAST-IRON-BAR-25-MM-...=item45f683b7ed
I seriously doubt it! |
