| Home > Help Needed / General Tech Chat > SPI running rich | |||||||
![]() 847 Posts Member #: 6673 Post Whore Worral Sheffield |
22nd Apr, 2011 at 10:10:24pm
My daily has just failed it's MOT on emissions, it's running at 7% co2!
22nd Apr, 2011 at 11:11:02pm
You need to get a propper diagnostic test done to find out whats really going on, but coolant temp is a common factor. Put short, if the ecu thinks the engine is not above 80c, its still in warm up. several mechanical factors can also generate this condition.
22nd Apr, 2011 at 11:20:02pm
cheers sprocket, I will post the full results tomorrow, but I know it failed on every test! |
23rd Apr, 2011 at 11:31:27pm
test one
24th Apr, 2011 at 01:11:32pm
Its deffo running rich and i'd say the cat is working, especially with the CO so high and the HC so low.
24th Apr, 2011 at 10:34:46pm
Thanks so much, there is a place just up the road from my parents house in manchester that solved a similar issues with my sisters escort, if i cant find a decent place in leeds that may be open this week i will get in down there early next week.
24th Apr, 2011 at 11:15:17pm
the white wires can go either way :) there polarity doesnt matter. turbo 16v k-series 11.9@118.9 :)
26th Apr, 2011 at 10:54:13pm
How much would you expect to pay for a session on a diagnostic machine? I have a 2 quotes for £55 to £65 for the first 30min Inc vat.
26th Apr, 2011 at 11:29:11pm
Now don't be a pussy and go and fit carbs in place of injection On 26th Oct, 2004 TurboDave16v said:
26th Apr, 2011 at 11:50:23pm
i do like pussy though! |
108 Posts Member #: 9182 Advanced Member |
27th Apr, 2011 at 02:25:27pm
You say you fitted a LCB, where is the Lamda located.It must be in or after the Y piece to get the correct readings. |
27th Apr, 2011 at 06:44:16pm
27th Apr, 2011 at 11:52:14pm
We got a maniflow LCB with the Lambda on the center branch. The reading at the tailpipe was lean because the outer cylinders run leaner.If somebody fitted the lambda to an outer banch of the exhaust I would assumn the opposite would happen.
Edited by viz139 on 27th Apr, 2011. |
28th Apr, 2011 at 12:25:54am
the lambda is fitted to the Center branch. I have not checked the temp sender yet havet had chance to look at it all week. the reading on the dash is allways bang on Center whatever the weather. but I think that goes off the sender at the bottom of the rad? and there is a second in the inlet manifold? I will get chance to have a good dig on Friday. if I find anything obviously wrong I will try and fix it or come down and pay you a visit sproc, if it pisses me off any more it's going in the bin! I have a carb on the way just worried about how to regulate the fuel as there is 3 lines currently. and hopefully nothing els will stop working if I rip out the spi loom |
28th Apr, 2011 at 01:37:19pm
On 26th Apr, 2011 maccamcvey said:
anyway mr Viszrd slags SPI off something rotten! Vizard is biased and old
If you don't have a balls out racer, you won't get better than fuel injection on the mini. Bring it round and let me have a look, but i think you have already set your mind on the carb I know two guys at Manchester Minis who retrofitted to SPi on a mild tune road engine and have been amazed at how good it actually is compared to the poor tune of the carb On 26th Oct, 2004 TurboDave16v said:
388 Posts Member #: 442 Senior Member Manchester |
28th Apr, 2011 at 08:11:13pm
I can vouch for that one. I may go that route when i eventually start my rebuild. |
