| Home > Help Needed / General Tech Chat > How to lock the gearbox? | |||||||
![]() 257 Posts Member #: 7048 Senior Member Bridgend |
23rd Apr, 2011 at 07:57:38pm
I need to take off my first motion shaft bearing and gear, so need to lock the first motion shaft.
Turbo parts collector at the moment, almost ready. |
23rd Apr, 2011 at 08:13:59pm
Remove the diff side plate on the right hand side.
23rd Apr, 2011 at 09:24:35pm
You need to twist the gear selector left and all the way over. 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
23rd Apr, 2011 at 09:55:06pm
Cheers, did that got it locked. Did the 1st motion shaft nut, but then it was stuck in what ever gears it was, and fiddling with it I managed too shoot ballbearings and springs across the workshop. I'll try again tomorrow on a new gearbox. Turbo parts collector at the moment, almost ready. |
24th Apr, 2011 at 09:02:21am
Bad luck...
