| Home > Help Needed / General Tech Chat > Cooling or not | |||||||
24th Apr, 2011 at 07:42:10pm
Been having a few issues with cooling:
24th Apr, 2011 at 08:06:48pm
I'm thinking about junking my mpi rad set up as it ran cooler with the minispares 2 core one. Even on the rolling road the temperature never climbed above 75 degrees. At combe it never rose at all even though I got the oil temps up to 120 degrees.
24th Apr, 2011 at 08:14:08pm
I'm thinking that this one isn't as good as the last? Did they go nla for a while and then the price went up. I wonder if it's for a different batch. Ihave flushed it and everything was clean, the first one was great it never got hot even on the lakes run which is a big test of any car..
549 Posts Member #: 5327 Post Whore Dudley, West mids |
24th Apr, 2011 at 08:20:13pm
I'm running a Minispares 4 core on my Turbo motor with no issues and no electric fan. It's never gone above half way. However my Minispares 2 Core used to overheat all the time even with millers super coolant in thats should reduce temps. |
25th Apr, 2011 at 10:15:50am
Anyone using these? Just making sure they are better and not e Chinese ones..
25th Apr, 2011 at 10:20:31am
as i said in my pm, they keep things nice and cool while your moving, when stuck in traffic they do rise to about half way, but never any more, once you get moving up to 40-50mph temps soon drop back down to the first mark. Audi s4 b5 - 470bhp & 486ft lbs
On 15th Mar, 2012 wil_h said:
25th Apr, 2011 at 10:33:09am
I have a 2 core i bought off of here, it struggles to keep the temp down even driving it sensibly!
25th Apr, 2011 at 11:28:07am
To throw somthing else into the mix...
25th Apr, 2011 at 02:19:33pm
Joec I get what your saying but it used to run cool? Not sure what's going on, are the alloy rads an upgrade in terms of cooling? Side mounted specifically? I run a supercharger and I don't care the TB is on the wrong side.
25th Apr, 2011 at 02:22:27pm
Did you chang your ignition map at all when it started running hot? I found with my old mini that if it was too far advanced it would run really really hot. On 11th Feb, 2015 robert said:
25th Apr, 2011 at 03:31:28pm
I have a Radtec and would not waste my money on any alloy radiator again I seriously doubt it! |
25th Apr, 2011 at 04:03:58pm
Mm I have don't some work on it this morning, I have removed the rad and flushed it again and all clear, I noticed some moly grease on it from the a gater split last yea I have given it a good clean.
Edited by gr4h4m on 25th Apr, 2011. I run a supercharger and I don't care the TB is on the wrong side.
25th Apr, 2011 at 08:09:59pm
Paul w you must have an alloy rad in that all alloy car of yours, it would be a sin not to have one.
