| Home > General Chat > Weak points of our engines???? | |||||||
22nd Mar, 2005 at 06:31:59pm
Right I?ve just had another rolling road. Edited by Miniwilliams on 22nd Mar, 2005. Best 1/4 mile 13.2 seconds @116 mph
439 Posts Member #: 275 Senior Member bonie scotland |
22nd Mar, 2005 at 07:03:20pm
lost 2 pistons difirent times piston split in 2 right through gudgeon pin using 8500rpm wrecking every thing apart from cylinder head, never found con rod only had top of the piston left |
22nd Mar, 2005 at 07:06:14pm
my bank balance is my weak point On 15th May, 2009 TurboDave said:
22nd Mar, 2005 at 07:07:57pm
on turbo A series my own experience are Mat.
22nd Mar, 2005 at 07:09:45pm
thrust washers due to heavy clutches needed for the high torque On 15th May, 2009 TurboDave said:
22nd Mar, 2005 at 08:18:38pm
Matt - WTF are you asking this???
22nd Mar, 2005 at 10:13:28pm
On 22/03/2005 20:18:38 TurboDave said:
Matt - WTF are you asking this??? Almost type something similar earlier.
23rd Mar, 2005 at 07:30:03am
On 22/03/2005 19:09:45 Jimster said:
thrust washers due to heavy clutches needed for the high torque You too?? :) I'll never get fed up of showing these:
In addition to the strong spring, I think this is also down to bad setup. I've never adressed this before We'll se now, now that the clutch has been PROPERLY setup.
23rd Mar, 2005 at 01:39:06pm
Dave and Jon, i wouldn't be posting this if i know the answer now would i, by the look of things nor does any one else:(
23rd Mar, 2005 at 01:42:32pm
Fair enuf Matt!
23rd Mar, 2005 at 02:45:30pm
"Something else I'd like to see introduced to the market is an overdriven idler set - where the 1st motion gear turns faster than the primary gear. The torque inside the 'box would drop by the same percentage as the ratio increase... "
AlexF |
23rd Mar, 2005 at 06:39:57pm
Thanks to every one that have posted.
23rd Mar, 2005 at 07:08:26pm
LOL! It wasn't aimed at you - just a general comment! On 17th Nov, 2014 Tom Fenton said:
23rd Mar, 2005 at 07:36:11pm
No your right though Best 1/4 mile 13.2 seconds @116 mph
![]() 928 Posts Member #: 326 Post Whore bradford, west yorks |
24th Mar, 2005 at 07:35:07pm
i as wonderignt his too as i want my car for every day use and thatss hwy i am keeping the power down to about 120bhp so it doesent need rebuilding every year. so how many miles should it really take with every day driving and the odd weekend at york?
24th Mar, 2005 at 07:47:21pm
Standard rods and bolts are very good items, as we dont need alot of revs to get power they will be fine. If you look after your engine with gegular oil changes etc, 120bhp should last many thousands of miles.(hard to say exact mind) -MINI CLUBMAN 1380 TURBO- |
24th Mar, 2005 at 10:10:59pm
you ought to get it setup once a year thou....
AlexF |
24th Mar, 2005 at 10:26:26pm
Dan as T3 said 120 bhp should last a while. As for the standard rods and bolts, in most cases you can't bet geniune stuff. i have had standard rods for years. Arp bolts are not needed for what you said you are after.
24th Mar, 2005 at 10:29:33pm
i will deffo get it set up enough times and get freindly with the RRs:)
24th Mar, 2005 at 10:34:26pm
good idea about the getting some sort of gauge, i would be going for a exhaust gas temp gauge rather then an air fuel gauge, but thats just me. Best 1/4 mile 13.2 seconds @116 mph
24th Mar, 2005 at 10:49:43pm
afr tells you egt in a rough kinda way!
Edited by AlexF2003 on 24th Mar, 2005. AlexF |
25th Mar, 2005 at 12:46:39pm
yor right the word is MOST gauges Edited by Miniwilliams on 25th Mar, 2005. Best 1/4 mile 13.2 seconds @116 mph
591 Posts Member #: 360 Stu from Corwall aka Mr Jazz Piano, Love_Machine, kneegrow |
26th Mar, 2005 at 10:22:00pm
The question which I often wonder with an O/D idler, where does the torque load go? I reckon that the idler bearings would get more cained.
Bugger off, I'm getting there. |
27th Mar, 2005 at 12:49:23am
i see what you mean about a/f ratio guages now i am a little more worried but i still want one lol
27th Mar, 2005 at 07:33:59am
lean mixture equals hotter gas...........
I'm only a carpenter you know! :)
