| Home > General Chat > rts clutch? | |||||||
26th Apr, 2011 at 07:02:27am
Hi, after a little help on the rts clutch as I'm a bit confused, I've had a search, found a lot of info but not what I'm after, is it 2 standard clutches I need or 1 ap clutch and 1 standard etc? What else is needed to make an rts clutch? What sort of price does it cost?
On 15th Mar, 2012 wil_h said:
26th Apr, 2011 at 10:09:07am
You just need 2 clutches of the same type wheter it be standard or AP.. You'll also need 9 shouldered M10 bolts and thick hardened washers, and preferably some 0.5mm sleeve to put over the bolts to bring the shank size to 11mm.
Edited by matty on 26th Apr, 2011. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
26th Apr, 2011 at 10:36:02am
Ok so could I buy a new standard clutch and then use the springs from my old used clutch or any old used clutch?
26th Apr, 2011 at 10:39:55am
Has the clutch your going to use got to be new? Or could I use 2 second hand ones? Audi s4 b5 - 470bhp & 486ft lbs
26th Apr, 2011 at 12:19:39pm
Also is it just a case of putting the 2 clutches together or do I need to get the flywheel machined or balanced? Ill be using my standard flywheel still. Audi s4 b5 - 470bhp & 486ft lbs
26th Apr, 2011 at 12:54:58pm
I just used 2 old clutches, but I fitted a new friction plate as the old ones were no good.
26th Apr, 2011 at 02:47:46pm
Ok think I've got it, cheers matty Audi s4 b5 - 470bhp & 486ft lbs
26th Apr, 2011 at 03:52:55pm
benny i have a valeo clutch or two kicking about the shed your welcome to have one
Yes i moved to the darkside |
26th Apr, 2011 at 04:13:36pm
infact if you can get the parts together i dont mind building it for you Yes i moved to the darkside |
26th Apr, 2011 at 04:40:45pm
pm incoming brett Audi s4 b5 - 470bhp & 486ft lbs
744 Posts Member #: 7912 Post Whore Australia oi oi oi! |
29th Apr, 2011 at 11:41:10am
i have one of these
29th Apr, 2011 at 11:47:49am
Thats an expensive way to do it Nick. If something is worth doing, it's worth doing half of. |
29th Apr, 2011 at 12:12:30pm
The way I'm doing it is costing me next to nothing to build, got 2 clutches for 20quid, some bolts for £4 and I just need spacers and then to get it balanced. Audi s4 b5 - 470bhp & 486ft lbs
29th Apr, 2011 at 02:03:47pm
On 29th Apr, 2011 John said:
Thats an expensive way to do it Nick. I own both lol.. so where do i go from there? help? |
