| Home > Help Needed / General Tech Chat > 18cc pistons head & boost | |||||||
461 Posts Member #: 9229 Senior Member newcastle upon tyne |
28th Apr, 2011 at 07:59:29pm
Hi just thinking on getting some omega 18cc from avonbar or med I've got a block that's never had a skim but needs a bore to a min 1293. I have a good ported head (12g940 if that's the right number you know witch one I mean) that's never been skimmed either & has totaly std chambers. now what sort of cr would I expect to see with that kind of combination & what sort of boost levels would be safe to run with? thanks scott Edited by scott the joiner on 28th Apr, 2011. |
28th Apr, 2011 at 08:04:55pm
Sorry buddy. Could you edit that post into sentences please? I'm struggling to make any sense of the post as it is. If something is worth doing, it's worth doing half of. |
28th Apr, 2011 at 08:07:56pm
I think you need to use this.
29th Apr, 2011 at 05:33:41am
From the figures given - about 8.7:1
29th Apr, 2011 at 06:55:42am
I've got an intercooler set up on & ignition is std metro turbo dizzy mite go mj in the future & fuelling will be adjusted & set up accordingly its currently set for 12.5 psi boost |
29th Apr, 2011 at 07:44:54am
If it is 8.7:1 then you could run loads of boost. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
549 Posts Member #: 5327 Post Whore Dudley, West mids |
29th Apr, 2011 at 08:27:58am
I've got the same set up.
Edited by madcatminis on 29th Apr, 2011. |
29th Apr, 2011 at 09:10:51am
I have a cr of 8.5:1, run a cossie intercooler, timing set at 25 degrees and I accidentally put 18psi through it when I split my signal pipe from actuator, everything was ok, no det etc. Audi s4 b5 - 470bhp & 486ft lbs
On 15th Mar, 2012 wil_h said:
29th Apr, 2011 at 10:24:49am
So about 15 sounds the safe bench mark for everyday use. Matcat have you any chamber mods at all? Or totaly std chambers? Bennyy is you timing fixed to 25deg across the whole rev range? & is it a dizzy or mj? Cheers for your help just need to plan me new build |
29th Apr, 2011 at 10:30:10am
29th Apr, 2011 at 12:18:10pm
15psi should be fine if fueling and timing are good, and mines just a turbo dizzy mate. Audi s4 b5 - 470bhp & 486ft lbs
29th Apr, 2011 at 02:28:15pm
Yes. Totally standard chambers. |
29th Apr, 2011 at 06:15:58pm
Bennyy is it a std turbo dizzy or has it been played with to lock it at 25deg or just std metro turbo still using the vacume advance with std curve thanks this is helping me loads after my rr set up the bloke put to much advance on & killed me engine so got to start from scratch |
29th Apr, 2011 at 06:21:28pm
just a standard turbo dizzy with vac advance disconnected Audi s4 b5 - 470bhp & 486ft lbs
