Home > Wanted > a+ gearbox
bennyy
Member #: 9037
Doncaster, yorkshire
After an a+ gearbox, casing must be in good condition, local to south yorkshire.
On 15th Mar, 2012 wil_h said:
On 30th Apr, 2012 Brett said:
Me and/or John should be able to help out. Is it for rebuild or to go straight in. Do you need the diff etc?
bennyy
Member #: 9037
Its for a rebuild, everything gonna be spankers mate.
OK, I'll sort you one out over the weekend.
bennyy
Member #: 9037
Ok cheers andy, let me know when you have one ill bob through
The one I have in mind is in John's container, will be heading over Monday at the latest. It's complete bar diff and final drive. Just need to check it's all there.
bennyy
Member #: 9037
That's no problem, cheers.
John will sort it along with that clutch.
Also, found a complete valeo flywheel in my shed if you want that too
