| Home > Help Needed / General Tech Chat > Pistons | |||||||
1170 Posts Member #: 8636 Post Whore Surrey |
29th Apr, 2011 at 02:33:21pm
So are these AE 21253?
Reading up on RTS Clutches On 21st Sep, 2006 Paul S said: Go on, be brave, put it in the car and tell us how it works. Pity your bollocks are in line with the flywheel! On 27th May, 2013 robert said:
putting my testicles on the line for turbo mini owners everywhere ,and they still work ! |
29th Apr, 2011 at 02:39:26pm
the price of them plus the price of machining is the same as my omegas then you have the running around and stuff to get them sorted
Yes i moved to the darkside |
29th Apr, 2011 at 05:06:47pm
Ahh ok, i work it out to be roughly
29th Apr, 2011 at 06:12:31pm
I believe Nick has run those pistons and they have stood up to a fair bit of abuse. On 11th Feb, 2015 robert said:
29th Apr, 2011 at 06:15:51pm
Yeah, so i hear!
29th Apr, 2011 at 06:27:18pm
On 29th Apr, 2011 WRLondon said:
Ahh ok, i work it out to be roughly £175 for pistons £35 for machining so about £205? while omegas are £270+ and still need dishing out abit more than 10cc? Ill check out mini speed though, just down the road from me! How much did you get your omegas for? iirc the 10cc cast omegas have a 4cc ring land instead of the 0.8cc of the std turbo piston, so they shouldnt need machining any more, calculate your cr ratio without machining see what it comes to, i reckon it should be about 8.5:1, which should be about right, cannot be bothered to work it out tho
Edited by bennyy on 29th Apr, 2011. Audi s4 b5 - 470bhp & 486ft lbs
On 15th Mar, 2012 wil_h said:
![]() 489 Posts Member #: 9159 Senior Member Devon |
29th Apr, 2011 at 06:34:13pm
I'm going to be running 21253's on mine, i was lucky enough to take the head out to 28cc to get my compression ratio down to 8:5.1 so didn't need to machine them and i'm not planning on running much boost as i still have the helical box [but with x pin diff and sc drops]
29th Apr, 2011 at 06:37:26pm
ahh good point, Omega casts are about £270 arent they?
29th Apr, 2011 at 06:38:22pm
how much were yours jamestar?
29th Apr, 2011 at 06:41:50pm
i think mine were around £150-160 for some +20 21253's only a little bit cheaper than minispares but when you take into account postage costs etc... every little helps |
29th Apr, 2011 at 06:43:19pm
sounds good - may have a chat with minispares down at l2b
29th Apr, 2011 at 10:13:38pm
ive got my omegas measured up at 0.532 cc ring land volume
30th Apr, 2011 at 02:07:32pm
fantastic,
Edited by WRLondon on 30th Apr, 2011. Reading up on RTS Clutches On 21st Sep, 2006 Paul S said: Go on, be brave, put it in the car and tell us how it works. Pity your bollocks are in line with the flywheel! On 27th May, 2013 robert said:
