Home > Help Needed / General Tech Chat > Gear Reconditioning?
Star Mag
Member #: 375
Leicestershire
My gearbox has started to get a bit crunchy when doing a shift at high engine revs.
The problem is some of the coating on the gear cone where the baulk ring slows the gear has started to come off! Question is can this be re done or is the gear set scrap. Its a minispares clubman set if that makes any difference!
Cheers Ron
Doesn't Minispares do spares for those? IE the full gear?
Star Mag
Member #: 375
Leicestershire
Yes they do but was wondering if there was a cheaper option first :)
turbo hogster
Member #: 178
stowmaket suffolk
the gears will eb fine just change the rings mate, as its a cheeper option, the cone dia is a tad small, as long as you have 10 15 thou gap betwenn ring and engage teeth then all should be fine, what oil are you using
Scruffy
Member #: 328
Seaford Rise, South Australia
In answer to your question Ron you cannot have the syncro cone surfaces replated. Once these are worn - usually caused by running with worn baulk rings for too long it is new gear time. New baulk rings might cure the problem long enough to sell the car but no more than that!
On 5th Sep, 2011 Vegard said:
Star Mag
Member #: 375
Leicestershire
Cheers for the answers guys! I've always used millers ctv, but I think repeated blow ups hasn't helped!
I think a full strip down is in order to see what can be salvaged hopefully I cane get away with just changing a couple of gears!
nutter driver
Member #: 47
Not very sunny swanage
If they are moly coated, and not plated then they can be redone, but it's not really cost effective to be honest...
nutter driver
Member #: 47
Get some decent pics up if you get a chance!
