Home > Help Needed / General Tech Chat > pipe size from actuator to turbo?
bennyy
Member #: 9037
Doncaster, yorkshire
managed to split the pipe above from where I mounted my bleed valve, going to get some straight from work and forgot to check what size the pipe is,
On 15th Mar, 2012 wil_h said:
On 30th Apr, 2012 Brett said:
3mm ID should be sufficient
we use 4mm on the van
bennyy
Member #: 9037
Cheers lads.
