| Home > Help Needed / General Tech Chat > Timing chain or tappet noise?? | |||||||
3rd May, 2011 at 09:49:19pm
I've got some noise from my engine and I'm off to slark on Saturday, I want it sorted before I go ideally.
Edited by almichie on 4th May, 2011. On 7th Nov, 2011 apbellamy said:
![]() 130 Posts Member #: 9395 Advanced Member |
3rd May, 2011 at 10:59:21pm
Link not working |
4th May, 2011 at 07:31:21am
4th May, 2011 at 07:50:36am
tried without the rocker cover on the check that the rockers does not hit it making this noise? |
4th May, 2011 at 09:06:05am
As above, are they making contact with the cover? I have to push mine backwards when fitting to make sure that they clear.
In the 13's at last!.. Just |
4th May, 2011 at 11:20:58am
Ah, I have had that on a supercharged engine with a high lift cam.
4th May, 2011 at 11:27:39am
It does sounds very much like valve clearences to me.
4th May, 2011 at 05:30:40pm
but watch the screwdriver isnt near any moving parts or it will go through your head
4th May, 2011 at 09:41:51pm
sounds like valve clearance here too, only on a couple valves though i would have said Yes i moved to the darkside |
