| Home > Help Needed / General Tech Chat > t3 advice please | |||||||
29 Posts Member #: 9081 Member |
4th May, 2011 at 09:36:56pm
Hi my t3 turbo is no good so ime looking into getting another
4th May, 2011 at 09:43:36pm
there are many different types of t3, its the metro / mini version you need if you want to keep it standard, the others are for much larger engines Yes i moved to the darkside |
162 Posts Member #: 9342 Advanced Member Southern Norway. |
4th May, 2011 at 10:48:34pm
Rebuild it with new seals and bearings? or buy a center core completely balanced and use old housings? :)
5th May, 2011 at 07:50:04pm
hi what will need replacing if i rebuild it. where do you get those center cores from then
5th May, 2011 at 08:41:31pm
A £30 rebuild kit from eBay is sufficient to resolve most problems. There's also lots of guides if you google. In the 13's at last!.. Just |
5th May, 2011 at 10:07:12pm
ok ive found a rebuild kit on ebay theres loads of guides on google but whats the best guide you lads use to rebuild them i havent got a clue so lots of pics and easy to understand please:) thanks chaps. |
![]() 130 Posts Member #: 9395 Advanced Member |
6th May, 2011 at 12:46:38am
From experience, when you come to strip the T3, soak the bolts that hold the exhaust turbine section in liberal amounts of WD40 over several days, as I didn't do this and ended up snapping two bolts costing me to have them helicoiled |
6th May, 2011 at 08:23:37am
Don't forget to mark the compressor wheel and shaft! :) |
6th May, 2011 at 11:02:02am
lee, get a kit and bring it oves mine and il help you do it. 13.95 1/4 mile on a 2.95 fd. Carnt be that hard to beat! |
6th May, 2011 at 05:44:58pm
On 6th May, 2011 eden7842 said:
lee, get a kit and bring it oves mine and il help you do it. now theres an offer you cant refuse
7th May, 2011 at 08:56:29pm
Ok cool thanks all best place to get a kit there's some on eBay are the kits all the same. |
1300 Posts Member #: 829 Post Whore essex |
7th May, 2011 at 09:47:30pm
like this http://cgi.ebay.co.uk/Turbo-Rebuild-Repair...=item5adbf0d7ad 1293 Turbo mini
