| Home > Help Needed / General Tech Chat > dumpvalve fitment and standard plenem | |||||||
5th May, 2011 at 11:13:33pm
hi, i have fitted a standard metro plenem body with a maestro neck to allow for intercooler fitment.
5th May, 2011 at 11:16:27pm
bung up the std relief valve, aparently a load of 5p's under the spring should do the trick. On 28th Aug, 2011 Kean said:
7th May, 2011 at 02:56:51pm
thanks joe.
7th May, 2011 at 03:20:59pm
I've had one where the bottom part of the neck which retains the spring is chopped off and replaced by a metal plate.
In the 13's at last!.. Just |
1300 Posts Member #: 829 Post Whore essex |
7th May, 2011 at 10:54:13pm
you can use car filler to block the hole 1293 Turbo mini
