| Home > Help Needed / General Tech Chat > No Spark Megaolt | |||||||
![]() 2054 Posts Member #: 452 Post Whore Chester, UK |
6th May, 2011 at 07:39:36pm
Ive searched the thread but if possible i want to know a bit more details.
6th May, 2011 at 07:42:03pm
go you hae 12v going to the contre pin of the coil? On 28th Aug, 2011 Kean said:
6th May, 2011 at 07:48:04pm
yup, the coil and edis are fed buy the coil wire in my loom. |
6th May, 2011 at 07:58:50pm
righto,
1300 Posts Member #: 829 Post Whore essex |
6th May, 2011 at 08:54:26pm
have you run the engine just on the ford unit first to see if it runs and what is the air gap on the sensor ? 1293 Turbo mini
7th May, 2011 at 12:13:21am
sorry to seem stupid, so to test the edis if i disconnect the pip and saw wires and just leave them connected to nothing it should spark?
Edited by t@z on 7th May, 2011. |
7th May, 2011 at 12:24:13am
yep disconect the pip and saw, and you should get fixed timing.
7th May, 2011 at 01:13:46am
T@z I would say its the sensor gap too mate. I have started posting on Instagram also my name on there is turbomk1golf
7th May, 2011 at 10:08:18am
thanks guys, i'll disconnect the pip and saw and look at the sensor gap and see if that helps; also got to pop to Maplins to get a new multimeter as my one doesn't test continuity....fingers crossed
![]() 257 Posts Member #: 7048 Senior Member Bridgend |
7th May, 2011 at 12:06:28pm
Try putting your multimeter across your VR sensor, you should get a reading of a few volts from it. Turbo parts collector at the moment, almost ready. |
7th May, 2011 at 12:43:37pm
also if you can get onto one of the Coil A, Coil B wires at cranking speed you should be able so see it going 12v 0v 12v etc
7th May, 2011 at 01:43:34pm
well strange, i dc'd the MJ and made a better earth as i wasn't really happy with the one yesterday and sparky.....connected the MJ and still a spark so top dog :) thanks for your replies defiantly helped me in starting where to look.
7th May, 2011 at 06:17:53pm
Mate when i first fitted my setup, I just got a smail fuse box (from halfords) and run all the MJ bits on its own.
7th May, 2011 at 10:14:38pm
i would solder all the joints 1293 Turbo mini
8th May, 2011 at 09:21:40pm
On 7th May, 2011 jimmy said:
i would solder all the joints all the other joins are solered, i only didn't do those ones as last time i got the + and - the wrong way round on the sensor and had to re cut them :) |
