| Home > Help Needed / General Tech Chat > Charge Cooler | |||||||
![]() 259 Posts Member #: 9335 Senior Member Bromley, SE London |
7th May, 2011 at 04:31:08pm
Im toying with the idea of using a charge cooler rather than an intercooler. From the research i'v done there are arguments saying charge coolers are only good for track & sprints where as others disagree and say they're good for road use too. Its neither here nor there really, but I'd like to know if anybody else has done it before? - from what i'v seen nearly everyone has an intercooler.
7th May, 2011 at 06:27:13pm
IMO Dont, break the mould, Edited by BENROSS on 7th May, 2011.
![]() 141 Posts Member #: 7472 Advanced Member stockton on tees |
7th May, 2011 at 06:41:01pm
I have a chargecooler on my focus Rs as from standard and does the job but there is just more on them too go wrong as the pump has just gone on mine. Andy |
7th May, 2011 at 06:48:09pm
What got my attention was this on ebay.
7th May, 2011 at 06:54:25pm
That item in question was a homologation exercise by Ford so they could use a charge cooler on the works Escort Cosworth rally cars. It isn't big enough to do anything useful on a road car, but was good enough to get it homologated.
Edited by Tom Fenton on 7th May, 2011.
7th May, 2011 at 07:20:07pm
Charge coolers are fine for the road. If you are tight for space up front they are perfect and can be just as efficient as intercoolers. The downside is the added complexity and the extra weight.
http://www.twin-turbo.co.uk
1300 Posts Member #: 829 Post Whore essex |
7th May, 2011 at 10:57:27pm
what hp we looking at ? by cooling the air temp 1293 Turbo mini
297 Posts Member #: 2276 Senior Member sheffield / derby |
7th May, 2011 at 10:58:48pm
i still have one for sale if you interested??
152 Posts Member #: 1074 Advanced Member Northamptonshire |
8th May, 2011 at 09:39:50am
I run a Pace cooler purely because it is very difficult for me to package an air/air intercooler. However it does seem to work well. On a hot day under fast road use (around 1 bar boost ) I'm seeing intake charge temps around 15-20 deg above ambient which is not too bad.
Edited by matnrach on 8th May, 2011. |
8th May, 2011 at 02:51:39pm
water or air cooling isnt as important as efficient cooling.
8th May, 2011 at 05:20:49pm
On 8th May, 2011 stevieturbo said: nice and neat
water or air cooling isnt as important as efficient cooling. Water is always better IMO, but obviously it makes for a more complicated and heavy install. For those saying water is no use, that's just plain wrong. If you build and implement a flawed or inadequate setup that doesnt work. That isnt because of the water, it's plain bad design. It would be like saying a woefully small intercooler is crap because it is an A2A intercooler. No it's crap because it hasnt been specced to suit the needs of that engine. Likewise with A2W systems. Spec it right, and IMO water is better. But A2A is much easier and cheaper and nothing can really go wrong with it. 1293 Turbo mini
8th May, 2011 at 07:35:38pm
What are the rules to spec'ing an intercooler and charge cooler then?
Edited by carts60 on 8th May, 2011. |
162 Posts Member #: 9342 Advanced Member Southern Norway. |
8th May, 2011 at 07:59:45pm
Hmm, wouldn't this just heat up the water to 90c? Edited by Utking on 8th May, 2011. |
8th May, 2011 at 08:02:56pm
Well obviously there would be some heat sink, but I wasn't suggesting the charge cooler would share the same water supply. Obviously it would have its own - achieved through splitting the rad.
8th May, 2011 at 08:11:57pm
hmm, how would you split the radiator? I don't think you could overcool it, as there are cars that use charge coolers with dry ice. Unless that's to cool for you :cool: |
8th May, 2011 at 08:29:50pm
Ha. Too cool for school.... never!
8th May, 2011 at 08:33:02pm
The best way to keep the two water systems separate, is to do just that. If the two radiators are together within one unit, all you would do is soak heat from the hotter one to the cooler one and make yourself a nice charge heater. On 11th Feb, 2015 robert said:
8th May, 2011 at 08:47:42pm
haha. I'll stick to the basics then lol |
charge coolers are superior for the 1/4 mile but not practical for road application, and i guess that you want to runn your car on the road and the track, stick to a good intercooler, sprayed mat black to give its heat up more and your well sorted
if you use a seperate radiator, you could keep it at almost ambient temperatures :)
