| Home > Help Needed / General Tech Chat > No rpm signal from megajolt - Ignore/delete thread please | |||||||
8th May, 2011 at 02:32:02pm
Todays problem is that I have fired the car up for the first time this year after another semi rebuild and cannot get a rpm signal. At first I thought the connection from the tacho to the megajolt may be loose however having now plugged it in to the computer while running It still will not give a rpm signal, only TPS.
Edited by minimole23 on 8th May, 2011. On 7th Oct, 2010 5haneJ said:
8th May, 2011 at 02:34:44pm
The edis plug wasn't quite clipped in properly, so would run but only on edis rather then megajolt. - panic over:) Edited by minimole23 on 8th May, 2011. On 7th Oct, 2010 5haneJ said:
1300 Posts Member #: 829 Post Whore essex |
8th May, 2011 at 05:22:44pm
well done 1293 Turbo mini
