| Home > Help Needed / General Tech Chat > Clubman sc set | |||||||
107 Posts Member #: 9276 Advanced Member Darlington north east |
10th May, 2011 at 08:53:09pm
Hi everyone.
10th May, 2011 at 11:34:19pm
dont forget the 1st motion shaft bearing and the double roller bearing and the diff bearings and you want a x pin diff in there diff oil seals remote repair kit oil seal and of corse the gaskets
1300 Posts Member #: 829 Post Whore essex |
11th May, 2011 at 12:22:03am
what about a set of s/c drop gears if you are doing the gearbox 1293 Turbo mini
![]() 1105 Posts Member #: 1504 Post Whore Westbury, Wiltshire |
11th May, 2011 at 02:09:33pm
As Steve's list above.
11th May, 2011 at 02:35:57pm
I thought they used the standard 1st gear? Audi s4 b5 - 470bhp & 486ft lbs
On 15th Mar, 2012 wil_h said:
11th May, 2011 at 03:06:31pm
depends if you get a 4 piece or a 6 piece gear set On 11th Feb, 2015 robert said:
12th May, 2011 at 09:18:35am
On 11th May, 2011 apbellamy said:
depends if you get a 4 piece or a 6 piece gear set No. The Clubman set is 4 piece, and the ST set is a 6 piece. 1st gear being the additional one. Edited by Vegard on 12th May, 2011. On 13th Jul, 2012 Ben H said:
12th May, 2011 at 07:24:34pm
I'm sure all I had to do was re-use my reverse gear when I built my SCCR box with the Minispares Clubman gearset.
12th May, 2011 at 10:07:35pm
On 12th May, 2011 turbominivanman said:
I'm sure all I had to do was re-use my reverse gear when I built my SCCR box with the Minispares Clubman gearset. Richard 1st gear as well. On 13th Jul, 2012 Ben H said:
