| Home > General Chat > cam belt kit | |||||||
1300 Posts Member #: 829 Post Whore essex |
11th May, 2011 at 10:57:30am
1293 Turbo mini
11th May, 2011 at 10:58:34am
Good point no chatter.
11th May, 2011 at 11:02:09am
On 11th May, 2011 John said: what the belt snaped ?
Good point no chatter. Bad point ask Joe C Edited by jimmy on 11th May, 2011. 1293 Turbo mini
11th May, 2011 at 11:45:50am
teeth stripped due to oil contamination
11th May, 2011 at 12:14:51pm
i see so it was down to oil on the belt 1293 Turbo mini
11th May, 2011 at 12:15:19pm
On 11th May, 2011 Joe C said:
teeth stripped due to oil contamination bent 8 valves on my 7 port head, dinged the pistons, ruined the conrods, trashed the cam, fucked the push rods. I'm a bit wary of the later chinese belts, At some point Im going to look at putting together a cam belt drive using an MGF VVC belt, much sturdier. Ouch!!!! Audi s4 b5 - 470bhp & 486ft lbs
On 15th Mar, 2012 wil_h said:
11th May, 2011 at 12:17:01pm
was that turbo or n/a 1293 Turbo mini
11th May, 2011 at 12:27:00pm
click the link in his signature. It's a long read, but it's worth it. On 11th Feb, 2015 robert said:
11th May, 2011 at 12:30:41pm
cheers 1293 Turbo mini
11th May, 2011 at 04:50:46pm
I'm a bit wary of the later chinese belts, At some point Im going to look at putting together a cam belt drive using an MGF VVC belt, much sturdier. No need to waste your time, its already been done http://www.shengineering.co.uk/sh/content/...timing-belt-kit On 26th Oct, 2004 TurboDave16v said:
11th May, 2011 at 04:53:40pm
that looks good 1293 Turbo mini
11th May, 2011 at 04:55:57pm
11th May, 2011 at 06:31:12pm
I thought the SH one used the usual profile belt rather than a proper cam belt one. On 28th Aug, 2011 Kean said:
11th May, 2011 at 06:45:59pm
that has adjuster on the belt 1293 Turbo mini
