Home > General Chat > Weight reduction - front hubs
Has any of you guys tried shedding some weight off the front hubs? I know the flange can be machined, the only bit i can think of is the rear part where the drive shaft goes in.
Mike
DaveVader
Member #: 9075
Peterborough
I've often found that losing a bit of weight off the rear part makes it look generally nicer and is more pleasant when the shaft goes in.
My dirty mind has twisted this somewhat!
*Rofl!*
Gavin Wakely
Member #: 793
Just by tidying up the casting you will loose weight and it will look better.
Anyone got any pics?
You could try drilling some holes in them *happy*
Johnny
Member #: 6926
Accrington
+1 John hahaha
Pretty sure I shaved just over 200g from each of mine, though theyre on the daily drive now
remove the bearing ,that will save some weight
I thougt of removing my brake discs as theyre pretty heavy. Bit too important i spose!
Bin them calipers too.
Who needs brakes anyway
DaveVader
Member #: 9075
Peterborough
Hold a coat out the window... instant air brake.
Rick.SPI
Member #: 8027
Bin the brakes and cut a hole in the floor, 2 birds with one stone, you'll loose weight in the front and the floor and be able to brake via the soles on your shoes. *wink* on a serious note, anyone got any piccies of lightened hubs?
What about disk bells being ally they would save alot of weight, could even do a full bell and flange setup possibly, i have been thinking the same about reducing the hub weight and the rear radious arm, would love if somewhere did tubular ones off the shelf or something
Rick.SPI
Member #: 8027
