Home > Help Needed / General Tech Chat > Low dashpot oil?
wagon_rider
Member #: 9241
Edinburgh / Dumfries
Did low oil in the dash pot at some stage in the life of the carb cause this?
*oh well*
Cheers!
The oil is there for damping purposes.
wagon_rider
Member #: 9241
Yeah but why has it corroded at the top? It was totally wedged into the suction chamber (is that the right name?)
It moves up and down OK now after I sanded it a bit :S
wagon_rider
Member #: 9241
Oh and when i emptied the oil out of it it was fill of grit :(
bennyy
Member #: 9037
Doncaster, yorkshire
The dashpot oil is only to damper as above, shouldn't there be a thin groove for a circlip there? Is there any groove?
On 15th Mar, 2012 wil_h said:
On 30th Apr, 2012 Brett said:
wagon_rider
Member #: 9241
no I don't think so, Just a bit of rust and it almost looks like somebody hit it with something as the edge is a bit bent
Its an HS4
HS4 didn't have the circlip. Only HIF's I believe.
jimmy
Member #: 829
essex
what have you justed for oil 3in 1 oil ?
1293 Turbo mini
bennyy
Member #: 9037
didnt realise it was a hs4.
wagon_rider
Member #: 9241
I've never used oil - Only just bought it 2nd hand! *frown*
I thought general motor oil is OK? Should I Use 3 in 1?
wagon_rider
Member #: 9241
sorry I should have said
tadge44
Member #: 2500
Buckinghamshire
My guess is that the carb has stood for some time and its condensation and rust caused that pitting.
