| Home > Help Needed / General Tech Chat > RH indicator not working | |||||||
12th May, 2011 at 08:15:00pm
hi guys my right hand indicator seems to be knackerd. if i put it on to indicate right, the side repeater and rear light come on and stay on, the front lamp is off. the left works fine. If i put the hazards on, they all flash fine apart from the front right lamp which stays off. iv removed the bulb and its fine, so my thinking is that the bulb holder is gone or the wiring to it. any ideas?
12th May, 2011 at 08:18:14pm
I would guess either wiring between hazard switch and front indicator., dirty bulb holder or bad earth on the front indicator. On 11th Feb, 2015 robert said:
12th May, 2011 at 08:22:09pm
On 12th May, 2011 apbellamy said:
I would guess either wiring between hazard switch and front indicator., dirty bulb holder or bad earth on the front indicator. cheers il look into the dirty bulb holder, as thats easier then trying to trace a wiring fault. |
1300 Posts Member #: 829 Post Whore essex |
12th May, 2011 at 09:50:05pm
i would check the wiring in the front grill 1293 Turbo mini
