| Home > Wanted > Phase 2 or 266 | |||||||
![]() 1434 Posts Member #: 8466 Post Whore Mansfield |
13th May, 2011 at 02:16:03pm
I guys, just checking your thoughts, I'm just about to fit an alloy front plate and alloy venier duplex. Was considering swapping my phase 2 for a billet 266. My engine is now almost finished, but am worried the phase 2 may be to hairy. I really want a smooth engine to pull from 2k. Max 16psi boost. I plan to fit my 7 port head later this year with SC injection kit and custom plenum, fir this I will run higher CR 8.8-1, and slightly less boost. How does the phase 2 drive, lumpy? Off cam? Etc. Basic engine spec 1293, med offset 36x32 head, omegas, T2 hybrid, mirage etc. Class C 3rd Place Avon 2011 14.18 @101mph |
13th May, 2011 at 03:55:00pm
if you fancy selling the ph2, presuming its in good condition ill take it off your hands. Audi s4 b5 - 470bhp & 486ft lbs
On 15th Mar, 2012 wil_h said:
13th May, 2011 at 05:19:49pm
time the phase 2 at 107 they are very civalised at that and pull well early on
13th May, 2011 at 05:40:09pm
I don't think the phase 2 is a bad cam drivability wise. It certainly isn't 'lumpy'.
In the 13's at last!.. Just |
13th May, 2011 at 06:33:27pm
I think I'll stick with phase 2, I had timed it in at 108 with steel venier. Why now 107 Steve? What do you guys rev the phase 2 too. Isn't it called a hungry hippo? Class C 3rd Place Avon 2011 14.18 @101mph |
13th May, 2011 at 06:40:16pm
Do they work better at higher boost levels. anybody ever run one on a n/a? Class C 3rd Place Avon 2011 14.18 @101mph |
13th May, 2011 at 06:40:39pm
Phase 2 will peak about 6 and redline about 6500, maybe a little bit higher.
13th May, 2011 at 06:51:35pm
Almost tame? Compared to what it N/a terms. I don't plan to drive flat out all the time. I getting really pissed off with my current engine (1380, str930, full race spec) I hate driving it slow or any where near traffic, but on the other hand I've also had 1330 with Sw5 and got bored after 20 miles. Edited by alaskanow0 on 13th May, 2011. Class C 3rd Place Avon 2011 14.18 @101mph |
13th May, 2011 at 07:00:51pm
compared to a 296 its a pussycat, thats the beuty of turbo, smooth idle and flexible, but will snap your neck when you boot it! On 28th Aug, 2011 Kean said:
13th May, 2011 at 07:11:40pm
Joe - is the C for Carlos Fandango? On 11th Feb, 2015 robert said:
13th May, 2011 at 07:14:59pm
yep!
Edited by Joe C on 13th May, 2011. On 28th Aug, 2011 Kean said:
![]() 825 Posts Member #: 2208 Post Whore Essex |
13th May, 2011 at 11:29:20pm
:) its a fun cam, still getting used to mine
On 13th May, 2011 Joe C said:
compared to a 296 its a pussycat, thats the beuty of turbo, smooth idle and flexible, but will snap your neck when you boot it! |
14th May, 2011 at 12:13:17am
It's worlds apart from a lairy NA cam. It might not make peak power till further up the revs, but the rest of the rev range is usable. In the 13's at last!.. Just |
