| Home > Help Needed / General Tech Chat > Heater with turbo bulkhead box | |||||||
![]() 130 Posts Member #: 9395 Advanced Member |
13th May, 2011 at 09:16:12pm
Just interested to find out how everybody deals with the heater inside the car when a turbo bulkhead box is fitted
1300 Posts Member #: 829 Post Whore essex |
13th May, 2011 at 09:22:36pm
just make new brakets mate 1293 Turbo mini
13th May, 2011 at 09:29:44pm
If I can help it, I don't want it sticking out further than the std one, as I want to make a centre console |
13th May, 2011 at 09:42:49pm
i see 1293 Turbo mini
13th May, 2011 at 09:44:36pm
Make the brackets shorter. Before I changed my dash the heater fitted in it's original location with a bulkhead box.
In the 13's at last!.. Just |
14th May, 2011 at 08:48:17am
On 13th May, 2011 theoneeyedlizard said:
Make the brackets shorter. Before I changed my dash the heater fitted in it's original location with a bulkhead box. Depends on whose bulkhead box. I've got one of Jason's boxes and with the brackets as short as physically possible my heater is about 20mm further back inside the car. But Jason's boxes are a lot deeper than most of the commercial ones so it should be possible to keep it in the same position with a "standard" box. Schrödinger's cat - so which one am I ??? |
14th May, 2011 at 10:23:27am
Just drop the brackets at the rear so that the base of the heater is lower than the front. On 11th Feb, 2015 robert said:
![]() 1105 Posts Member #: 1504 Post Whore Westbury, Wiltshire |
15th May, 2011 at 12:47:49am
I've used a Mk2 heater. The one with the bakalite body in two halves held together with clips.
