Home > For Sale > Benross Turbo Race Head for Sale
alaskanow0
Member #: 8466
Mansfield
I have for Sale a Benross Turbo Race Head, Purchased a year ago, but never fitted. The Head was order from Steve to full race spec, his top spec cost £605. The Head has 35.7 x 29 Strainless Race valves, 3 angled seats, Fancy Valves Seats. Quality Valve Springs.
Since purchasing the head, its undergone considerable more work, including smoothing out the internal porting, opening and matchng ports to Turbo manifold gasket. Push rod sleeves were required and installed for exshaust ports. The Head also needed to be skimmed by 8thou to ensure no head gasket problems. Its been drill for 11 Stud. The work was done by Peter Burgess, Autor of "How to Build, Modify & Power Tune Cylinder Heads" Qualiity Job , Further Cost off £200.
The Chambers now have 24.5cc chambers, were 25cc before been skimmed. I was sure I ordered 28cc, but definatly measure 24.5cc with spark plug install (measured by Peter at his unit and confirm by my measurement this evening.)
Ready to fit £550 ono
Edited by alaskanow0 on 14th May, 2011.
jimmy
Member #: 829
essex
can this cylinder head be used on a turbo set up
1293 Turbo mini
alaskanow0
Member #: 8466
Mansfield
Yes this is designed for turbo, sorry missed turbo in description. I guess it would be fine for both applictations.
Utking
Member #: 9342
Southern Norway.
damn, nice head :) wish i had the money =/
george91
Member #: 8932
If Mr benross can vouch for this then i'm interested. :)
Also is there any reason for sale, if you don't mind my asking.
Edited by george91 on 14th May, 2011.
alaskanow0
Member #: 8466
Mansfield
I'm fitting a Med FIS offset head with 32mm exhaust valves, That I bought of Cossierick. See my build thread "my first turbo". Don't need 2, at one stage was planning turbo for both my minis. The med head will let my run slightly more boost due to lower CR, but is not unleaded like the Benross head. Being thinking about which one to use for a while. Both will be for sale at some point as I will need to rise funds for my plenum and injection setup to move to 7 port.
gurky
Member #: 9525
do you still have this item ?
