Home > Beginners Tech > Noisy idler?
Simon
Member #: 1865
Norwich, Norfolk
Today is the first day my car has been started and on the road in 10yrs so i'm going to start popping up with quite a few questions now.
With the car on idle there is quite a noise/rattle coming from the engine, someone at the MOT station called it a diesel. anyway, upon pressing the clutch pedal the 'rattly' noise soon went away, but returned on releasing the clutch.
I have SC drops and a timkin idler, does this sound normal or do I need to check something?
Utking
Member #: 9342
Southern Norway.
hmm, i thought it was suppose to rattle a bit at idle with SC gears?
EricsAmerica
Member #: 7891
Annapolis, MD USA
Straight cuts will rattle...don't worry about it...they also whine like crazy while you drive too.. *Yes*
Eric
my pics.... http://www.fototime.com/inv/7AAF37CF3EFA956
This is normal for SC drops.
Simon
Member #: 1865
Norwich, Norfolk
cheers guys, the whine i was prepared for just not the noise on idle
yes this is normall and the noise gets worse when the oil is hot nothing to worry about
turbominivanman
Member #: 1504
Westbury, Wiltshire
Might be worth just raising the idle speed a little as the noise does abate a small amount but to be honest, you're probably stuck with it as that SC combo is destined to be as loose as they get.
I guess I'm a bit sad really but that noise on mine is kinda reassuringly nice in a strange kinda way !
I just love the look on peoples faces when you pull up next to them and they think the gears are about to come out the bottom of the car !
Richard.
Edited by turbominivanman on 15th May, 2011.
