Home > General Chat > Finding an adapter-Driving me crazy!
dischub
Member #: 8143
London
I'm trying to find the following adapter
1/8" BSP Male to 1/8" NPT Female, long enough to accept a coolant sensor
Can't find one anywhere except the states, the only other way is converting to AN which ends with a pretty long network of an-npt adapters!
Any help?
Give Think Automotives a call
dischub
Member #: 8143
London
Thanks Rob, they are local too!
Mate that is where i was that day i called around to see you, its not far from you at all.
Simon
Member #: 1865
Norwich, Norfolk
you could try here too https://www.europaspares.com/ I used them to get my 1/8 NPT (F) to 5/8 UNF (M).
dischub
Member #: 8143
London
Simon (Madmk1) they're not far at all! Hopefully they'll have it
Simon I tried europa, I thought they nearly had it but it turned out the adapter was 1/8bsp at the female end and 1/8" at the npt end! doh!
metroturbo
Member #: 989
North Yorkshire
Is this any good?
http://www.premiair-pneumatics.co.uk/webca...uctCode=S010131
jamie@thefatgarage
Member #: 9345
Sheffield
As a backup option, you can make them from 2 others and cut/weld in the middle to end up with the ends you want. I've done it a few times when I can't get the combination I need.
