Home > Wanted > Intercooler Piping
Amp
Member #: 7856
Morning all,
Before I start buying bits from ebay etc, anyone on here got any leftover intercooler pipework joins/bends? I have plenty of 51mm stainless straight pipe, but need some silicon (or aluminium/stainless) bends/reducers/connectors!
Anyone got anything? For an idea, i'm using the standard metro turbo plenum, and a cosworth 2WD intercooler (63mm take-off).
Edited by Amp on 15th May, 2011.
bennyy
Member #: 9037
Doncaster, yorkshire
ive got one straight 63-51mm reducer i was going to use but never did? £7 posted?
Edited by bennyy on 15th May, 2011.
On 15th Mar, 2012 wil_h said:
On 30th Apr, 2012 Brett said:
Mate dont forget about the TM discount.
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=394388
simon.
just_jack
Member #: 2928
peterborough
Ah beaten to it, do what Simon said, with the discount he sorted, there is some great prices
Jack Jones
Amp
Member #: 7856
Cheers Benny, i'll bear it in mind, looking at yours i may try to find a 63-51mm reducer incorporating the 90 degree bend, as essentially I have your set-up :)
Cheers madmk1, I have seen the discount before but ebay prices are still competitive against silicon hoses!
bennyy
Member #: 9037
For the right hand side end tank you need a 90 reducer, cut it down as much as possible and cut down the take of on the end tank too otherwise your bonnet won't shut flush, it takes a bit of tweaking to get it to sit right, mine just about closes nicely now.
For the left hand side I was going to use the straight reducer then a 90 bend facing upwards to get up over the servo, but instead I just used a 45 I had lying around.
