Home > Help Needed / General Tech Chat > electrics
chesh
Member #: 9470
wiring loom is melted in engine bay. engine will start but nothing else lights front and back or horn.
do i just need a mini wiring loom or would i be best with a metro turbo one
Edited by Nick on 15th May, 2011.
Nick
Member #: 154
Midlands
depends on whether its in a metro or a mini?
if your car with the melted loom is a mini i would recommend getting a mini loom
If it is a mini, then its a mini loom you want
jimmy
Member #: 829
essex
i have a full wiring loom for a mini late one but before you start taking out wiring loom what do you mean melted what can see burn cables ?
1293 Turbo mini
Eh?
jimmy
Member #: 829
essex
ok then can you see burn out wiring ?
1293 Turbo mini
100ev8
Member #: 9138
wolves
why has it burnt in the first place ?
dont touch th old loom without rubber gloves on !!
http://www.fishfight.net/
jimmy
Member #: 829
essex
why ?
1293 Turbo mini
Carcinogenic
why ?
before you change the loom though, you should work out what caused the issue in the first place; no point wrecking a good new loom because something else is knackered
