Home > Wanted > Wanted - Collects And Spring Top Caps
tomf
Member #: 1746
Kent
Well i think my mum has thrown away my envelope with all my collects and top caps, so i need some more.
I need 4 x single groove collets with spring caps, i also need 4x large single groove collets with spring caps (i belive these ones also have a clip that went over the collects on the outter side of the spring cap)
Heres a pics of the valves:
They dont need to be new or anything, just as cheap as possible.
jimmy
Member #: 829
essex
good old mum always there when you need them lol
1293 Turbo mini
philc
Member #: 1346
bromsgrove
i think i have some spring caps, i will have a look. is this what you are after http://www.minispares.com/Product.aspx?ty=...id=42154&title=
tomf
Member #: 1746
Kent
Thanks for getting back to me, no sorry philc those are valve stem oil seals, i need spring caps, they hold the springs under pressure and lock the collets in place.
philc
Member #: 1346
bromsgrove
mmmm i do know something about engines, honest *frown*
kenny2
Member #: 5362
wexford in ireland
are they for 998?
On 5th Jan, 2011 wolfie said:
tomf
Member #: 1746
Kent
I belive the large grove collect ones are from a 998, and the small collect ones are from a 1275.
EDIT: I am just guessing here though as i have only seen large groove collects on a 998 before.
Edited by tomf on 18th May, 2011.
kenny2
Member #: 5362
wexford in ireland
i've a few 998 heads thrown around i'll have a look for ya in a while
kenny2
Member #: 5362
wexford in ireland
just stripped 3 heads 2 have small groove collets and the other has triple grooves, if there any use let me, alternativly i could send ya a full set of valves and collets, kenny
tomf
Member #: 1746
Kent
Thanks for looking for me kenny, really appreciate it.
Ill defo take enough collects and spring caps for 4 x small grove valves.
Are any of your valves 30.7mm? if yes ill also take 4 of those with collects and spring caps.
Let me know how much you after and ill sort that out for you.
kenny2
Member #: 5362
wexford in ireland
just gettin dinner i'll be back in the garage after i'll measure the valves
tomf
Member #: 1746
Kent
How did you get on?
kenny2
Member #: 5362
wexford in ireland
all my heads are small valve, however the lad that built my enginesays he has a spare 1275 head belong to me out there, i'll find out asap for ya
tomf
Member #: 1746
Kent
I think its a pretty rare valve, i think they were only fitted to the cooper s heads and some 1100....
How much are you after for 4x valve caps along with collets for 4 valves. (the small single groove)
kenny2
Member #: 5362
wexford in ireland
one of the heads i checked i think is a 1098,
if its just the collets and caps i'll throw them in an envelope,
tomf
Member #: 1746
Kent
I belive its an inlet valve on some of the 1100 heads, but not all of them....
kenny2
Member #: 5362
wexford in ireland
pm me your address, i'm away from sunday for a week so if your in a hurry i'll stick them in tomorrow,
tomf
Member #: 1746
Kent
Thanks to kenny iv now sorted the small groove collets and spring caps.
I dont suppose anyone have some large groove collets, spring caps and possibly top clips do they?
If not do you know where i can get some?
tomf
Member #: 1746
Kent
BUMP
kenny2
Member #: 5362
wexford in ireland
i'll be pulling my n/a 1275 apart next week, wat size valves did you say they were?
