Home > Help Needed / General Tech Chat > Roller bearing drop gear, Measurements needed
LukeAnsley
Member #: 193
Does anyone have a roller bearing drop gear that they could take a couple of measurements from for me please.
I am after the o/d of the shaft that goes into the gearbox housing and the o/d of the other end of the shaft (clutch housing end)
Thanks very much.
Luke
Amp
Member #: 7856
Mine (fitted to a box) reads 27mm which sits in the transfer housing, gearbox side I don't know as it is fitted!
LukeAnsley
Member #: 193
Is this the type that sits in a needle roller in the transfer housing. The figure seems too small for what im after. I am looking for the measurement of the type without a bearing in the housing.
Thanks
Luke
