Home > Help Needed / General Tech Chat > n/a 998 help
eden7842
Member #: 8852
leicestershire
hey
bare with me on this one
got a lad with a stock 998 who came to me asking to get it to run right. atm it revs up fine but doesent drive above 1500 rpm. when it came to me it was running a shocking 60 degrees advance without the vac and i cannot get it to run at any less. The engine has been rebuilt by someone and this problem has started since, so its leading me to think that the cam has been put back in wrong. but as ive never seen this i dont know of the result.
am i on the right track ?
thanks in advance, eden
Kean
Member #: 341
aka T2clubby
South Staffs
Surely the cam will have no little effect on the ignition point?
Are the leads on the distributor in the correct place/order?
Get it to TDC and check both valves are closed on number one (take rocker cover off) and that the rotor arm is pointing to number one also.
Hope this helps
eden7842
Member #: 8852
leicestershire
well thats what i wanted to know as i wasent sure if it would affect it. i did do some basic checks but didont have much time
60 degrees advance, I'm suprised it runs at all.
Cam timing is a good place to start if everything else checks out. If it's miles out then it will cause all kinds of runing issues.
