| Home > General Chat > how do you put pictrue on | |||||||
1300 Posts Member #: 829 Post Whore essex |
17th May, 2011 at 06:40:46pm
how do you upload pictres on this form i can not work it out 1293 Turbo mini
17th May, 2011 at 06:51:35pm
best thing is to upload them to photobucket then copy and past the img link. On 28th Aug, 2011 Kean said:
17th May, 2011 at 06:55:26pm
whats a img link 1293 Turbo mini
17th May, 2011 at 07:03:18pm
Once you upload the picture there will be 4 links underneath, you need the img link Audi s4 b5 - 470bhp & 486ft lbs
On 15th Mar, 2012 wil_h said:
17th May, 2011 at 07:04:04pm
quote this post in a reply and below you will see the web adress of the pucture with img tags at either end, this tells your pc to display a picture and where it is, the first thing is you need to upload the picture to the web, I use photobucket as its easy.
17th May, 2011 at 07:18:29pm
On 17th May, 2011 Joe C said: i we give it a try
quote this post in a reply and below you will see the web adress of the pucture with img tags at either end, this tells your pc to display a picture and where it is, the first thing is you need to upload the picture to the web, I use photobucket as its easy. ![]() 1293 Turbo mini
