Home > General Chat > Cost of rebuild?
Craigie-B
Member #: 9468
Wootton Bassett
Hey guys, should be getting a metro turbo lump this weekend, was wondering how much its cost you guys to get your engines reconditioned both doing it yourself and employing a company to do the work for you. Also does anybody know where standard metro turbo pistons are readily available and how much for? Assuming you guys change the pistons when you recon the engine.
Craig
bennyy
Member #: 9037
Doncaster, yorkshire
if your going to the trouble of rebuilding the full engine, forget standard pistons, get some 1293cc pistons, the 10cc cast omegas are very good, take your block and pistons and get the block bored out
cost of rebuild depends on what needs doing, quality of parts etc.
On 15th Mar, 2012 wil_h said:
On 30th Apr, 2012 Brett said:
Craigie-B
Member #: 9468
Wootton Bassett
I was kind of hoping to keep the costs down as money tends to come in drips and drabs haha *tongue*
Theres an engineering company near me that could bore it out - what would I tell them "its a 1275 atm and id like it to be 1293" Cheers
hazpalmer
Member #: 9038
Carlisle, Cumbria
yeh i wanted it bored plus '20 for these pistons, because the pistons wont be exactly plus 20
You buy pistons and take them the block and the pistons. They will measure the block and pistons and bore appropriately.
As far as I'm aware standard metro turbo pistons are NLA and chances are your bores will be worn unless it's a very low mileage engine, which it won't be *wink*
carts60
Member #: 9335
Bromley, SE London
I'm in the process of getting parts for building a turbo motor. I must have spent about £800 already including the price of the engine, and thats using all used parts pretty much. I still don't have everything i need, but if you're frugal you can pick up some real bargains here and there. I picked up an RS Turbo intercooler off ebay for a fiver last week! Though im new to turbo'ing id say if you don't have all the bits already and you're on a budget, you'll be looking at around a grand to build the motor, more if you're going to rebore it.
Edited by carts60 on 18th May, 2011.
Craigie-B
Member #: 9468
Wootton Bassett
yeah okay guys, funny you should mention the rs turbo intercooler - I was watching that myself haha! Im getting the t2 turbo for £35 off a friend so that should be good.
With regards to the re-bore if I go to 1293 will I still use the standard headgasket or will I have to use an enlarged one?
hazpalmer
Member #: 9038
Carlisle, Cumbria
most people use the BK450
Craigie-B
Member #: 9468
Wootton Bassett
awesome! Thank you *happy*
standard head gasket should go all the way up to 1380 with out problem
Craigie-B
Member #: 9468
Wootton Bassett
Just worked it out to be about £1765 all in excluding getting the engine bored out *indifferent* seems to be alot more than I anticipated :S
Any chance of a breakdown of how you come to that price?
hazpalmer
Member #: 9038
Carlisle, Cumbria
what parts are you replacing?
Craigie-B
Member #: 9468
Wootton Bassett
heres what I worked it out as:
Engine - £300
MPI tank - £75
t2 turbo - £35
metro turbo plenum - With Engine
boost piping - £150
intercooler - £50
mirage manifolds - £350
dump valve - £75
cylinder head gasket set BK450 - £25
Alloy 2 core radiator - £75
electric fan kit - £110
fuel line 8mm - £35
Omega 1293 Pistons - £355 avrclassics (www.avrclassics.co.uk)
spark plugs - £15
coolant temp sensor - £15
ht leads - £25
clutch - £50
oil - £25
Edited by Craigie-B on 18th May, 2011.
Cam, Rebore, Followers, bearings, oil pump, gaskets/seals, diff, clutch, Carb, Head, gearbox, Distributer/MJ, etc etc?
Or is this covered in your £300 engine?
I paid £310 for 1293 omegas from avonbar recently
Craigie-B
Member #: 9468
Wootton Bassett
im getting an almost complete engine so I was counting parts being usable, such as the cam, head, gearbox etc
usable, but boring...
Craigie-B
Member #: 9468
Wootton Bassett
yeah lol, but I need to get it working first before i can indulge in it some more :)
hazpalmer
Member #: 9038
Carlisle, Cumbria
im guessing your guaranteeing the engine to be in good nick. You'll need to look at the crank, crank shells etc check for wear. Look at all the parts that can wear out.
Craigie-B
Member #: 9468
Wootton Bassett
yeah so it could be more =[ I was really hoping it wasnt going to be very costly - I mean when we get to £2000 im half way to a b18c4 vtec conversion :S
wng691s clubby
Member #: 9252
Cleethorpes
why dont you do a basic overhaul of the engine you are getting (bearings ect)get it up and running while you save up for the right stuff
Done now needs redoing lol
Craigie-B
Member #: 9468
Wootton Bassett
what parts would I need to buy for a basic overhaul, this sounds like what I would want to do - Im new to engine rebuilding so anyhelp would be great :)
thanks
wng691s clubby
Member #: 9252
Cleethorpes
check cam, crank bearings piston rings cam followers ect,if the engine your getting comes with a turbo you might want a rebuild kit im sure if iv missed it will be added
Edited by wng691s clubby on 18th May, 2011.
Craigie-B
Member #: 9468
Wootton Bassett
so changing pistons isn't required??
