Home > Help Needed / General Tech Chat > Car skitches sideways a little under hard cornering, dampers on the way out/gone?
Just wondering what might be causing it, other than the fact the car is lowered a little on standard dampers (Have some protech dampers coming to myself in the near future anyway), or the only other thing i can think of causing it would be the tyres on my new wheels. Theyre falken FK07E tyres on 10's , only done a couple hundred miles on them now, and my old tyres were the Falken ZE912 on my old 12's and didnt really find them a problem tbh. Opinions welcome, Toe is perfect, front camber is about -0.5 to -1 degree, castor is as factory, the rear i havent got much of a clue about, but it looks to have slight negative camber and doesnt crab at all.
Jason G
Member #: 1459
En-suite user
Braintree, Essex
Could be anything mechanical....even your driving style to be honest. What exactly is the car doing? Not sure what Skitches means..........
Edited by Jason G on 18th May, 2011.
On 19th Jan, 2010 wil_h said:
You say caster is as factory. this makes me think that you have asumed that it is as it was, even though you have lowered the rear and added camber to the front.
I have found that lowering the rear a lot gives the handling effect you describe. Raising it will probably sort it out. but otherwise you need to check the front caster.
Double check all the front subframe mounts, if they are not solid.
jimmy
Member #: 829
essex
i would make the rear 25mm higher then the front rear tyre pressure to high have you checked and have you checked that you are not topping the rear shocks out
1293 Turbo mini
Yoshimura
Member #: 9204
Amsterdam...Edinburgh
From my point off view .... you got enough advice allready so I will not share my upinion.....;-P
Front subframe is solid mounted, the castor is definately as factory as i have adjustable heavy duty tie rods and had that done with front toe, the car sits about level front to rear, maybe ever so slightly higher on the rear. What i think is happening is that the dampers arent really doing a lot, and according to a friend, the cars bouncing a little too much, so im guessing as it bounces its lifting the rear wheels upward slightly, then skitching a tiny bit over to whichever way the G's are pulling
Edited by Carlzilla on 19th May, 2011.
