Home > Help Needed / General Tech Chat > Boost guage
madonminis
Member #: 9371
East Yorkshire
Hey guys, just after some info on where you plumb your boost guage into, also what runs off the banjo bolt on the inlet manifold besides the servo (which I've removed)?
Just starting to get to the point now where the car is coming together nicely and should be ready to start it up soon. Oh and where do you run your oil feed for the turbo from, is it safetest to take it from the pipe that runs to the oil filter or the pressure sensor.
Thanks again guys
Matt
plumb the gauge to somewhere on the inlet manifold,
usually just the servo runs from the banjo bolt, althugh on metro's there is an anti run on valve that is best binned,
take the turbo feed from there the oil pressure switch is, there are adaptors available so you can still run the switch and or a guage.
wintersurferuk
Member #: 2208
theres a diagram somewhere round hear.
jamestar
Member #: 9159
Devon
this one?
wintersurferuk
Member #: 2208
this might help as well
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=257121
jamestar
Member #: 9159
Devon
Is there any reason why you can't take it from on the carb where the vacuum pipe goes to the dizzy, obviously only if you are running megajolt??
madonminis
Member #: 9371
East Yorkshire
I'm just running on carb for the time being while I build the car, will probably run a nice set-up in a couple of years.. This is most hopeful, thanks a lot guys
