Home > General Chat > verto lightened flywheel?
bennyy
Member #: 9037
Doncaster, yorkshire
There doesn't seem to be many about, and the ones I have seen don't use the pre-engaged starter, which ones do you lads use/ reccomend etc?
On 15th Mar, 2012 wil_h said:
On 30th Apr, 2012 Brett said:
Are you sure you have that right? I bought an MED one and it has a pre engaged ring gear.
Why anyone would want to fit an inertia ring gear onto a Verto flywheel, escapes me.
bennyy
Member #: 9037
Yes my bad, just had a nosey on MED and found one, cheers.
carts60
Member #: 9335
Bromley, SE London
Minispares do ones that should be cheaper than MED.
http://www.minispares.com/Product.aspx?ty=pb&pid=37371
to fit the high torque starter that they already had *wink*
MED will do them with either ring gear, but you might have to wait a little bit.
