Home > Help Needed / General Tech Chat > Electric fans
1310turbo
Member #: 41
does anybody run an electric fan aswell as the standard fan, and also what do you think would work best, the electric fan to blow against the rad or run it in the opposite direction to blow away the hot air??
A-series power! 1972|1310|T3 turbo|Omega pistons|Cantre main strap|Orange clutch diaphragm|AP race plate|Comp pressure plate|Lightened steel flywheel|13-row oil cooler|Vernier duplex timing gear|Phase 2 Piper cam|Green air filter|Hi boost carb needle/spring|2"Stainless exhaust|3"Play mini stainless rear box|Jack Knight s/c 4spd gearbox|Jack Knight s/c drop gears|Silicon coolant hoses|Lumenition HT leads|GAZ lowered height shocks all round|Steel flip-front|Rear safety devices cage|Group 5 arches|6x12 deep dish Minilites|Surf blue/Old english white|
Carl
Member #: 95
liverpool-on-sea
im running an electric fan as well my mini is a 1993 so it had an electric fan in the innerwing so i just wired in a switch and when the temp creeps up just switch it on and it seems to work fine
ProjectPunto
Member #: 22
i run an electric fan only on my car.
Pacet 11" on a std 3 core rad...no problems noticed on its first 40 minute run.
