| Home > Help Needed / General Tech Chat > pushrods rubbing | |||||||
194 Posts Member #: 1296 Advanced Member Milford Haven Pembrokeshire |
19th May, 2011 at 09:15:19pm
Here's the engine spec.
19th May, 2011 at 09:31:58pm
try it without the plate and only one gasket.
19th May, 2011 at 10:44:49pm
Thanks for the reply.
19th May, 2011 at 10:47:42pm
machining the rocker bases wont fix it as when the rockers come down they rotate. On 28th Aug, 2011 Kean said:
19th May, 2011 at 10:47:57pm
Also, thought about drilling out the pushrod holes, but on a ported head it would end with hole!! |
19th May, 2011 at 10:50:39pm
On 19th May, 2011 Joe C said:
machining the rocker bases wont fix it as when the rockers come down they rotate. Just thought the angle would be corrected from the addition of the decompression plate |
20th May, 2011 at 07:36:07am
How 'ported' has this head been? Have the push rod holes been sleaved? On 26th Oct, 2004 TurboDave16v said:
20th May, 2011 at 09:09:22am
It has been quite extensivly ported, but no sleeving.
![]() 140 Posts Member #: 1367 Advanced Member Cape Town, South Africa |
20th May, 2011 at 10:43:43am
Think about it.. machining the post just drops the pivoting point.. Machining the posts will put the rocker at a strange angle with the valve closed.. I have a feeling longer rods are the best fix Edited by CR# on 20th May, 2011. |
20th May, 2011 at 11:06:08am
the follower drops, so the pushrod drops, that in itself dosent affect the geometry....
On 20th May, 2011 mini23 said:
It has been quite extensivly ported, but no sleeving. Also, I was thinking about the reprofiled cam. That should not make to much difference as its the follower that determines the position of the bottom of the pushrod, so thats unchanged. Going to try a set of non A+ rockers this morning and if they dont work, i'll remove the head, try it with one gasket and failing that, i'll elongate the pushrod hole On 28th Aug, 2011 Kean said:
20th May, 2011 at 11:31:20am
Surely instead of reprofiling cams, machining things, spending money on new push rods and generally trying to make a 'bodge' work.
20th May, 2011 at 11:53:28am
what he said!
On 20th May, 2011 matty said:
Surely instead of reprofiling cams, machining things, spending money on new push rods and generally trying to make a 'bodge' work. Wouldn't it just be easier to do it properly and enlarge the chambers on the head? When you weigh up, time/money trying to get the decomp plate to work against whipping the head off for machining and slapping it back on (with 1 head gasket) its a no brainer...or am I missing something? ![]() On 28th Aug, 2011 Kean said:
20th May, 2011 at 12:16:13pm
Yeah I agree what he said. lol https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
20th May, 2011 at 10:37:47pm
Surely instead of reprofiling cams, machining things, spending money on new push rods and generally trying to make a 'bodge' work. Wouldn't it just be easier to do it properly and enlarge the chambers on the head? When you weigh up, time/money trying to get the decomp plate to work against whipping the head off for machining and slapping it back on (with 1 head gasket) its a no brainer...or am I missing something? ![]() Was expecting this type of answer, but this was an experiment to use parts that I had avaliable which could be assembled and made to work in a simple manner. The rocker issue is sorted now with a non A+ set. Yes I could chamber out the head, but then it will always be a turbo head. Its easy to call a budget project a bodge and I could acuse others of this time and again, but dont. I have an out and out race engine with the best of just about everything, so would be in a position to critisise if I felt like. |
