Home > Help Needed / General Tech Chat > boost
turbo hogster
Member #: 178
stowmaket suffolk
took the hog out today for the first time and she went well . but i have only 2.5 to 3 psi boost at the moment.
what i was wondering is what is the relaxed distance from the actuator arm hole to the waste gate pin need to be to run 4 to 5 psi.
she has got a standard actuator.
ideal is about 6mm preload reckon. that doesnt mean it will give a certain amount of boost. trial and error will do it, or just bleed some off of fit a new actuator. most are very tired by now *smiley*
T3Tone
Member #: 252
Sunny suffolk
I have a recon standard actuator that i got with the turbo hoggy if thats any use to yer?
-MINI CLUBMAN 1380 TURBO-
turbo hogster
Member #: 178
stowmaket suffolk
il keep with this for the mo and as ainsaid i will bleed of for the extra 2 psi, when head is ready then i will crank it in a bit and see, if not i may take you up on your offer or go like you and get a billet one.
T3Tone
Member #: 252
Sunny suffolk
billet??? only swapped for a 6.5psi one from an RSTurbo i believe?
check ebay, i got my billet one off there for ?11 *smiley* for my t3 and just got a spanking new one for ?50 for my t25
Edited by iain on 28th Mar, 2005.
Disk full (/tmp/#sql_c9d4b_0.MAI); waiting for someone to free some space... (errno: 28 "No space left on device")
