| Home > Help Needed / General Tech Chat > Replacing Floorpan - sorry 1 more question 21/5/11 | |||||||
1083 Posts Member #: 8932 Post Whore |
20th May, 2011 at 12:22:09pm
So i needed to replace my front floorpan, but since removing and fitting the new one it just looks a bit crap; and i'm too much of a perfectionist to just leave it.
Edited by george91 on 22nd May, 2011. |
20th May, 2011 at 12:36:32pm
I'd go for this panel. They are easy enough to fit, but you need to take into consideration the panel you need to remove to fit it (rear bins etc).
Edited by matty on 20th May, 2011. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
20th May, 2011 at 12:58:13pm
Thanks matty, i need a new x member anyways, and i don't have rear bins so that helps. |
95 Posts Member #: 9314 Advanced Member Chippenham, Wilts |
20th May, 2011 at 01:12:56pm
I used the half panel's with built in sills and cut them down, got them from Somerford Mini's
Edited by Ratty on 20th May, 2011. |
20th May, 2011 at 04:26:50pm
thanks for the info, i think i might go for the complete floor.
20th May, 2011 at 04:46:29pm
I would make some brackets up where the rear subby mounts to the heels board, so you can locate the new floor and bolt it in place at the back.
20th May, 2011 at 08:18:14pm
Thanks again matty, no doubt it will be a pain in the ass to do but well worth it. Cheers :) |
21st May, 2011 at 11:59:50pm
Ok so i've bought the panels, and i've been having a look at how i'm going to do it today in preperation.
22nd May, 2011 at 08:53:19am
Yeah I usually drill them (not all the way through the panel though) and I then use some grips to peel the panels away. A flapper disc works well to clean the ede up after.
