| Home > Help Needed / General Tech Chat > strange idle | |||||||
![]() 2057 Posts Member #: 9252 Post Whore Cleethorpes |
20th May, 2011 at 03:25:40pm
hi guys just a quick one for you im currently running a 998 with a hs4 1 1/2" now my idle some times is nice and low and other times its a bit high but it changes every time i get to a junction or set of traffic light and ideas?? Done now needs redoing lol |
20th May, 2011 at 03:43:35pm
those carbs are too big for a 998, id find some 1 1/4" 13.95 1/4 mile on a 2.95 fd. Carnt be that hard to beat! |
20th May, 2011 at 03:48:51pm
look for a vacume leak on the carb the pipes leading too and from, split maybe ? or to connected right, this is the first place to look.
20th May, 2011 at 04:09:58pm
its nly temporary whilst i build the turbo motor and its never played up before with some quite good performance too until my hg went recently and since replacing i iv had the carb problem il check the pipes over Done now needs redoing lol |
20th May, 2011 at 04:18:57pm
Maybe check the manifold gasket too, if you have had the head off.
20th May, 2011 at 04:27:12pm
i did gasket sealnt it but i didnt retighten nuts after a run i shall also try this. Thanks for the help guys great as ever il let u know if i sort it Done now needs redoing lol |
