| Home > Help Needed / General Tech Chat > Engin breathing heavy, oil contamination? | |||||||
![]() 825 Posts Member #: 2208 Post Whore Essex |
23rd May, 2011 at 01:50:00pm
Hello.
Edited by wintersurferuk on 23rd May, 2011. |
23rd May, 2011 at 08:49:15pm
Not a blown headgasket or bypass hose, loose thermostat bolt.
![]() 141 Posts Member #: 7891 Advanced Member Annapolis, MD USA |
23rd May, 2011 at 10:29:50pm
Not sure on #1, but #2 worries me. Usually bubbles and lots of outbound gasses means heavy blowby somewhere. I cracked a ringland on one of my pistons a while back and oil bubbled out of my breather filters... :( Eric
1300 Posts Member #: 829 Post Whore essex |
23rd May, 2011 at 10:39:51pm
for what you have put i would put it down as a worn engine mate the back fire maybe timing check your points gap first or it can be oiled on the exhaust valves (carbon) making it back fire 1293 Turbo mini
23rd May, 2011 at 10:42:35pm
I'll dig out my leakdown tester, get it mobile and we'll check it at garys. On 28th Aug, 2011 Kean said:
23rd May, 2011 at 10:43:31pm
On 23rd May, 2011 wintersurferuk said: if you remove the temp switch for the oil put a earth to the case of the switch and place it into some boiling water the gauge will go up
Hello. 1). Im not getting a reading for the oil pressure sender or the oil temp. when there earthed, the gauge works. 1293 Turbo mini
23rd May, 2011 at 10:56:15pm
I'm going over tomorrow to lend a hand.
In the 13's at last!.. Just |
23rd May, 2011 at 11:19:43pm
Gary As I said to Paulo earlier,
23rd May, 2011 at 11:34:51pm
Will try that out. If it works I'll make something up to earth them better permanently.
23rd May, 2011 at 11:45:04pm
its possible,
24th May, 2011 at 06:30:14am
There's an easy way to see if it's the rings.
24th May, 2011 at 09:48:05am
thanks for all the input!
24th May, 2011 at 10:16:59pm
earthed the sandwich plate, and the gauge is work now.
