| Home > Wanted > Metro Turbo engine | ||||||
![]() 966 Posts Member #: 358 Post Whore Snetterton, Norfolk |
27th Mar, 2005 at 09:06:29pm
After a Metro Turbo engine, condition not important cos i will probably rebuild it anyway. So long as basic condition is good, could do with carb, dizzy and gearbox though. |
Forum Mod 1140 Posts Member #: 93 Post Whore Near Lincoln |
28th Mar, 2005 at 06:40:27am
Don't worry about it being a "turbo" engine
28th Mar, 2005 at 08:13:53pm
Cheers dan,
29th Mar, 2005 at 09:49:50am
Im first in the que for one |
29th Mar, 2005 at 11:49:13am
find something like a G reg metro, that what mines from, it has the turbo stylee mains bearings in it
29th Mar, 2005 at 11:58:53am
been trying! lol! fingers crossed ive got an unlinered engine sat in the garage... hopefully i can pull it off the box tonight and find out! |
29th Mar, 2005 at 08:24:13pm
Nick,
29th Mar, 2005 at 08:40:23pm
nope, the shells have a tang that locate in the bearing housings.
![]() 2641 Posts Member #: 19 Post Whore newcastle |
29th Mar, 2005 at 08:46:49pm
mod normal ones its 5/10 mins per cap ... piece of P to do Edited by minimark on 29th Mar, 2005. Everyone knows that instructions only have to be read if the thing doesn't work....
30th Mar, 2005 at 08:18:18am
On 29/03/2005 20:40:23 iain said:
nope, the shells have a tang that locate in the bearing housings. also one half of the shell is grooved, the other is plain. ill take some photos when i split my engine and box hopefully tomorrow as its a late unleaded metty engine so should be like that. The late Metro bearings are crap. Much better to have main bearings that supply oil around the entire crank. I've seen some Metro blocks with two tangs, I'd use the old type EVERY time... Rather find a late Allegro Block, better material as well! A+ is rubbish... Apart from crank and pistons that is. On 13th Jul, 2012 Ben H said:
30th Mar, 2005 at 10:54:42pm
theres an old bloke with an allegro just up the road! Perhaps i shall go urban poaching tonight and get me an engine!!!! I didn't know that the allegro had an a series, i thought they were all 1600cc.
30th Mar, 2005 at 10:56:55pm
no had 1098 `s and 1275 in them Everyone knows that instructions only have to be read if the thing doesn't work....
30th Mar, 2005 at 11:37:01pm
On 30/03/2005 08:18:18 Vegard said:
Rather find a late Allegro Block, better material as well! A+ is rubbish... Apart from crank and pistons that is. I know where theres a w (1980ish) one is that classed as late,it looks like an a+ though with pre verto clutch
31 Posts Member #: 478 Member Ooop Norf (Cumbria) |
3rd Apr, 2005 at 10:14:14pm
I've got a 22,000 mile 1275cc Allegro unit 'n' box in my garage an i'm currently looking into building a turbo engine for my estate.
Clubbyestate : Brown and loud - fast soon ! |
3rd Apr, 2005 at 10:48:46pm
that sounds a bit like it from wot i heard!!!
3rd Apr, 2005 at 11:00:27pm
Unless you are going for a mega high powered engine, all the blocks are much of a muchness. A lot of people will tell you to avoid linered blocks, I have personally used linered blocks a few times in the past and have had no problems with them, but up to you. The crankshafts are also much the same, some of the early turbo engines had a tougher crank, but as the characteristics of the turbo'd a series are not towards high revs, this is not really essential.
637 Posts Member #: 429 Post Whore newcastle upon tyne |
4th Apr, 2005 at 03:56:07pm
ask alex f2003 if you can buy an engine of him!!! he got spares and he just got choppos mini turbo..surely he could do a deal?...worth a try |
5th Apr, 2005 at 12:14:56pm
On 03/04/2005 23:00:27 Tom Fenton said:
Unless you are going for a mega high powered engine, all the blocks are much of a muchness. A lot of people will tell you to avoid linered blocks, I have personally used linered blocks a few times in the past and have had no problems with them, but up to you. The crankshafts are also much the same, some of the early turbo engines had a tougher crank, but as the characteristics of the turbo'd a series are not towards high revs, this is not really essential. How very well put. Metro turbo block, Metro turborods... The same crap as all other A+ stuff..... On 30/03/2005 22:56:55 minimark said:
no had 1098 `s and 1275 in them And 1500 and 1750 O-series! :) On 13th Jul, 2012 Ben H said:
